Does anyone know is the 37x12.5x17 bfg KO2’s will fit on a on 2017 Raptor without rubbing? My truck has the icon 2.25” leveling kit. The 37” ko2 comes in at 36.5 inches and so I have a feeling they may fit without any rubbing issues but wanted to see if anyone could confirm this. I appreciate any feedback.
at 3/4 lock and a bit of compression, they will barely rub IF you really have the 2 1/4" which I say is actually 2" which means you'll get a bit o rub, but nothing bad.
if you get rub. The modification is really easy to eliminate it. The inner fenders on the Raptor are really easy to trim out . Simply identify (by turning the Wheel where the rub is. Mark it. Use a sraight edge or torpedo level to draw the lines. Enter the Dremel Tool ( see picture). This tool and wheel easily fits inside wheel well without having to remove the tire. It's a clean cut. Unless your looking for it you'd never notice it.
Thank you very much for the info everyone! Much appreciated. I'll post pics once I get the new wheels and tires and get them put on.
Checkout my thread on 37 inch tire fitment. Simply leveling the truck will not allow the 37 inch tires to fit. My thread runs the tires I fit tested as well as the wheel information on the Rotiforms I 'm presently running
