Washer Fluid Low
Discussion in 'Interior' started by Zaid Dahabi, Oct 29, 2017.
  1. Zaid Dahabi
    This is the 2nd time I run out of Washer fluid and the truck doesn't warn me!
    Does it usually warn or I got something wrong?
  2. Zaid Dahabi
    They do not have a 'LOW' Washer Fluid warning message! Shit! Just researched!
  3. RAM
    RAM Active Member
    There's no "LOW washer" warning on a 2017 Raptor? That's pretty sad.
  4. Rapere1
    Um, crazy i know. But if you use it a lot, check it more often. First world problems!!!!!!!
  5. Shark
    Shark Active Member
    Sounds like an opportunity to use one of those upfitter switches - install a camera under the hood so you can check your washer fluid level by just flipping a switch! ;)
    MtopRaptor likes this.
