Timing Chain Rattle??
Discussion in 'Engine Performance and Mods' started by jimmyv13, Jun 27, 2019.
  1. jimmyv13
    jimmyv13 Member
    I bought a ‘17 with 70K on it and I believe the truck has a timing chain rattle on a cold start. I know the previous gen 3.5 had a huge issue with this, but I didn’t know it continued with the 2nd gen. Anybody deal with this sound? I’ll post the YouTube vid when I get it uploaded.
  2. jimmyv13
    jimmyv13 Member
    youtube vid link:
    Damn, I am afraid this is a timing chain being stretched or cam phaser issue. Dealing with it right now.
  4. bravo3eco
    Yes, failed cam phasers. This 2nd gen ecoboost STILL has this same issue. Instead of fixing ($5k), sell it off and get something else. That will be the only way to escape.
    We are even seeing 2019s fail with this. It is an inherent design issue that Ford can't fix. Phaser design was updated twice so far with no positive results. Boggles my mind that people still get suckered into buying ecobosts.
  5. Hector Cueva
    Hector Cueva New Member
    just got mine back from dealer start around 7k and dealer wait until 20k to talk to ford luckily under warranty so far 5k more, no noise, cross my fingers.
  6. bravo3eco
    It will most likely come back... No new updated parts from Ford to fix this issue.
  7. Hookie
    Hookie New Member
    My 2018 with 20k miles is in the shop right now with the same issue. I had a 2017 with an oil consumption issue at 5k miles. I traded it at 14k miles for the exact same 2018 that is in the shop. Paid $5,000 for a second try.
    I love the Raptor but I’m over the build issues.
  8. bravo3eco
    It's more than that... It is DESIGN problems.
  9. Adam
    You are a design problem
    Full-Race and Vikes91 like this.
  10. mcgleevn
    mcgleevn Member
    perusing the Ford website and found a new special service message # 48168 regarding "ticking/tapping or rattle type noise on start up after a cold soak" >>> says possibly due to worn variable cam timing units, and then to replace all 4 of them - specifically states do not replace timing chain, tensioners, guides etc. unless inspection "clearly identifies a concern". SSM also states TSB will be published 4th quarter 2019... INTERESTING
    How do you guys feel about running 5w20 over 5w30?
  11. Adam
    I have heard the rumors about running different viscosity. I think it wont help much depending on what state and temps you encounter in the am. Some people I know have tried both and no results were clear. Interesting topic, I may go to Amsoil from people who tell me its the preferred oil for turbos.
