Ticking From Passenger Side
Discussion in 'Engine Performance and Mods' started by Caleb, Sep 16, 2017.
  1. Caleb
    Caleb Member
    Austin TX
    Does anyone else hear a ticking noise from the passenger side on cold start up?
  2. cyclers10
    I believe it's normal on cold starts
    Everything I start it cold it ticks. Goes away once it warms up
  4. vooodoo11
    vooodoo11 Member
    sounds like a exhaust manifold leak, not right
  5. shelteredraptor
    yup. well documented that there is a cold start tick, it goes away in 15 seconds or so. Personally, I am not inclined to let a tech start digging around looking for it. I can see that becoming a rabbit hole in a hurry....
    Agree
  7. Adam
    Mine does it for 10 or so secs too and goes away n turbos kick on n sound fine. My 2 cents.
  8. bravo3eco
    So.... other places are referencing a loose PCV to be the culprit. This is located under the engine cover, and under another foam/rubber isolator. Tighten that and you are good.
  9. Caleb
    Caleb Member
    Austin TX
    this is long and last 10 min or more, but is very faint or gone if I shut it down and restart it it does not have a set pattern. just wondering, I believe it is an electronically controlled noise and is normal but not a 100% sure
