Question for you guys I've had my gen2 for about 3weeks now and I've noticed that on the third break light the middle led is dimmer then the other 2 this was not the case on my gen1 so could someone check theirs and see if it's the same
Back from the dead thread. I also noticed this with my 2017 as well. Has anyone else noticed that Gen2 Raptors changed the third brake light housing design (reflector)? The early 2017s used the regular F150 housings, but clear lens. The problem, I think, is the LEDs are trying to shine thru the halogen reflector. The newer Raptors use a completely different third brake light housing now. All 3 LEDs are much more visible. I'll probably just buy the newer housing for better light output. Thoughts?
