Rattling over small bumps and rough road
Discussion in 'Raptor Maintenance' started by cwh, Jul 5, 2019.
  1. Manny
    Manny Member
    I had an annoying rattle up front and a local tire shop had to find the problem for me, because the ford “techs” told me it was normal from the live valve shocks. For me it ended up being shot upper control arm bushings. I bought Camburg arms and that loud noise went away.
    Now I’m only dealing with a small amount of feedback. I’m hoping these upgraded tie rods do the trick
    Good luck.
    How many miles do you have on that 19?
  3. Manny
    Manny Member
    Now? 16k.
  4. cwh
    cwh Member
    It’s been over two weeks and they still have my truck. They have no idea what’s causing the rattle. They escalated it to a Field Service Engineer and he doesn’t know what it could be. They all agree it’s not normal and somethings wrong. At what point do I have an argument as to how long they keep my truck and can’t figure it out? They are not going to give me a back broken truck and I’m not gonna wait two more weeks. Has anyone had any experience with something like this? Where the dealer can’t figure out what’s wrong and it’s still under warranty?
  5. Gerrit
    Gerrit New Member
    I'm getting a rattling issue in my 19 but only in 4 low. It started about 3 days ago and I have an appointment for August 6th. I only have 6k miles on it and have not spent a bunch of time off road. Hoping whatever it is doesnt take a month to fix.
  6. Gerrit
    Gerrit New Member
  7. bravo3eco
    Your issue sounds like one of following. Bad shock. Loose shock. Or loose control arm. Check front tires... Are they showing weird wear pattern?
    Keep in mind that the torque spec on front control arm is HUGE. This could be not fully torqued. I re-torqued mine and rattle over bumps went away.
  8. cwh
    cwh Member
    Yup. Bad shock. Bad internal valves they said. 37 days it took to have them figure it out. Now I have a fluttering noise on cold start ups. I can’t win.
  9. bravo3eco
    Cam phaser failure. I think this in the future of every ecoboost owner.
  10. cwh
    cwh Member
    Yup. Cam phaser. TSB.
  11. stevop007
    stevop007 New Member
    I narrowed the same noise down to my front driver-side brake caliper. It rattles over rough roads and makes a clunking noise over potholes. Took it to Galpin Ford this morning and they said its normal for that amount of caliper play and that they didnt hear the noise on the test drive... Front passenger-side caliper was solid as a rock compared to the wet noodle on the driver-side. Pretty sure the caliper slide pins and or bushings are worn and allowing the caliper to jostle around like it is.
    Had this same noise last fall and a different Ford dealer (Sunrise) said that my brake pads were rattling loose because the ants-rattle clip were missing.... I called BS but thats a whole other story for another time.
    In any event, Galpin Ford didn't charge me too troubleshoot and they're replacing my passenger side front CV axle because the boot is torn and spewing grease. Parts come in on Monday.
  12. cwh
    cwh Member
    mine was a faulty shock. Took them a month to figure out. Replaced shock and rattle is gone.
