OEM tire life?
Discussion in 'Exterior' started by MtopRaptor, Aug 13, 2018.
  1. MtopRaptor
    MtopRaptor Full Access Member
    hey all, just checking in to see what type of mileage you are seeing on your tires. I am at 16k and touching the wear indicators. Rotated with every oil change so I have somewhat even wear. The centers are a little lower than the outer, am running ~40 psi when warmed up.
    Thanks
    I have 25k miles and am not hitting the wear indicator yet. I figure I have another 10k or so miles. I rotate at every 5k miles as they is when i get my oil changed. Overkill maybe.
    23k Im good as well. Every 5k mine are rotated. Gonna have my 4th oil change this week.
  4. MtopRaptor
    What pressure are you guys at?
  5. Gdog
    30k also rotate every 5k. No abnormal wear running 38psi
  6. Vikes91
    38 psi too. It's on the door and I don't care to hear an argument like before how you should run what's on the tire.
  7. UnstableReaction
    UnstableReaction Active Member
    Key is mid oil change rotation 3500 or 5000. In the Florida heat, they are recommending 7500. Either way, I did the mid cycle rotation and all was good till last 7500 where I got lazy, and I wrecked the front tires to a point, end of life is about 30k.
  8. MtopRaptor
    Huh?
  9. Adam
    37,38 fronts 35 36 rears
    MtopRaptor likes this.
  10. TXFrog
    TXFrog Member
    I’m at 21k, and have rotated/etc. the dealer replaced 2 of my tires for free at 12k because one had a defect, and I told them it had to be replaced in pairs . Now, I have one bald tire, and one that is touching wear marks, the strangest tire wear I’ve ever seen. Waiting to hear if I’m getting 2 more! Wish me luck
  11. Adam
    Man 24500k, rotated every oil change which will be the 4th time next week and look good so far. Going to shoot for 40k ish than go to the KM3's OR Toyo M/T's
  12. UnstableReaction
    Dick Cepek
    LT315/70R17 FUN COUNTRY
    Purchased through 4Wheel Parts on warranty so with 5k rotation, they cover repairs or replace if necessary to 45k.
    A little more noise, but very close to K02 on highway.
  13. Ruben Romero
    Ruben Romero Member
    Albuquerque, NM
    Im at 17K miles. I dont have much tread left, maybe another 4-5K miles. However I do drive the truck like I stole it.
  14. Vikes91
    I'm at 29,000 miles and figure I'll get another 10k easy.
