New to the Forums and Raptors!! From El Paso, Tx
Discussion in 'New Member Check-In' started by Rodney Marcee, May 16, 2020.
  1. Rodney Marcee
    Rodney Marcee New Member
    2018 LeadFoot Raptor w/802A package
    I have done some Forscan mods, got the Bakflip MX4 bed cover. Wiretap with blender mount. BOV spacer
    Only question I’m trying to get my parking lights as DRL. I have tried forscan codes no luck. Any help would be awesome.
    Next modes are whipple intake, AMS Turbo Inlet, Rigid fogs, oil catch can and maybe AWE exhaust. Also open to suggestions!!!
    Raptor62430 likes this.
    Do you keep your headlights on auto?
  3. Rodney Marcee
    Yes, as well as tried other two settings. I’ve read threw forscan forum and F150 forums. I have the BCM 726-26-01 x1xx xxx xxxx and the 726-50-01 017F
    Update it Works!!!! Need the 726-45-01 xxxx-1Fxx-xxxx.
  4. Vikes91
    Sorry I have no other thoughts then.
  5. bravo3eco
    Since you have a 2018, have you checked to see if you have the plastic or metal oil pan? Any rattle on cold start?
  6. Rodney Marcee
    I have a plastic one and Cam phasers just got replaced at 26k
  7. bravo3eco
    Did you get the CD part numbers for cams? That would be latest.
    Keep an eye on the oil pan. The plastic is prone to cracking and leaking. Ford will only replace with plastic. The metal pan is not an easy swap out like you would think.
  8. Rodney Marcee
    This the ticket they gave me I think it’s hl3z 6c525 cd but I might be wrong. I did talk to my service advisor about the oil pan so every time I bring it in for maintenance they are checking it out for me. I wish it had a metal one. Thank you for the heads up!!!
  9. Raptor62430
    Raptor62430 Member
    San diego, CA
    2018 RAPTOR BUILD
    -COBB TUNING
    Ford Accessport V3 with TCM flashing-*
    AMS turbo inlet tubes-*
    COBB coolant overflow cover-*
    COBB Weathertech floor liners-*
    -AFE POWER
    Magnum FORCE stage-2 ‘Super Raptor’ Dual-3 1/2” Cold Air Intake System w/Pro 5R filter media-
    Rebel Series 3” 409 Stainless Steel Cat-Back Exhaust System-*
    -TURBOSMART
    Vee port EM Blow-Off Valve-*
    -SPD PERFORMANCE
    High Flow Turbo Exhaust Adapters-
    170 Degree Performance Thermostat-*
    -Eibach
    Pro lift-kit front springs-
    Bro, i get two work, and im just counting down the time till i can get back in my Raptor.
  10. Raptor62430
    Raptor62430 Member
    San diego, CA
    Sweet looking ride rodney
