Limiting straps Anyone know where to get a kit that is set up for the Raptor? Front, Rear, or both. Running Geiser springs up front and the rebound I feel is harsh on the shocks. And running Icon's in back also maybe a little harsh on the shocks also on the higher stage settings.
Yes I am. I run the truck often in sand dunes. So You will hit areas where it will push the suspension to heavy compression and then coming off a jump pushing the suspension to full extension. And with running a stronger then stock on the spring set up, just wondering if the shocks will hold up to this?
Camburg makes them, if you're jumping it id recommend getting some so you don't wear out your front shocks seals. I think khc makes some too
