Introducing the latest from Baja Designs, the LP9! A design that was inspired by the classic 8" La Paz light, the LP9 features modern styling and performance, with some of the most advanced LED technologies available today. The LP9 utilizes 9 forward projecting LEDS to produce 11,025 Lumens at 105 watts. An additional 6 LEDs make up the Integrated Peripheral Technology (IPT) which produces 1,140 lumens at 10.5 watts per side. The IPT provides 135° of high intensity light, as well as an additional 65° of comfort light. Overall, the LP9 provides 200° of usable light. The housing was designed to provide exceptional heat dispersion with Direct Ducted Cooling allowing for air to travel from the front of the housing to the rear. With a day-time running light, low, and high power mode light it will fulfill all your lighting needs. Available in a standard model that is perfect for a wide arrange of off-road use, as well as a Racer Edition configuration that is designed for the demands of high speed driving. The Racer Edition has similar power draw, but produces a much tighter pattern, providing higher visibility at greater distances. Pre-order going on now at ----->>>> CROWN OFFROAD Baja Designs Features: Satisfactions Guarantee Limited Lifetime Warranty – Complete Purchase Protection uService® – Replaceable Lenses And Optics ClearView® – All The Light, Right Where You Need It. MoistureBlock™ – Waterproof, Rain Proof, Submersible CopperDrive® – Only LED Driven At 100% 5000K Daylight – Less Driver Fatigue, Natural Color Specifications: Forward Projecting Lumens: 11,025 Utilizing 9 LEDs Forward Projecting Wattage/Amps: 105W / 7.6A IPT Lumens: 1,140 Utilizing 6 LEDs IPT Wattage/Amps: 10.5W / .76A Dimensions: 8" Diameter/ 3.25" Depth Weight: TBD LED Life Expectancy: 49,930 Hours Front Lens: Hardcoated Polycarbonate Housing: Hard Anodized Machined Aluminum Bezel: Billet Machined Aluminum Hardware & Bracket Material: Stainless Steel Exceeds MIL-STD810G (Mil-Spec Testing) Built-In Overvoltage Protection IP69K (Waterproof up to 9ft & Pressure Washable) IK10 Compliant (Mechanical Impact Testing) Patterns: Driving/Combo: Maximum trail coverage in a single light. The Driving/Combo pattern is equipped with both Wide Driving (42°) and the spot (6°) optics to provide you with a smooth blend of light for both near field applications and distance High Speed Spot: A longer and narrower 6° beam focus for illumination further down the trail or road. The Spot pattern is designed to be used in conjunction with additional Wide Driving and/or Driving/Combo beam lights. Pre-order going on now at ----->>>> CROWN OFFROAD Pre-order going on now at ----->>>> CROWN OFFROAD
