2019 Raptor oil consumption
Discussion in 'Raptor Maintenance' started by Rod Dash, Sep 9, 2019.
  1. Aandrews109
    Aandrews109 Member
    Second Oil Change on my '19 Raptor today. 2,500 miles since first change, Just over 5,000 miles total on the truck. If it used any oil during the second 2,500 miles, it was so little that I couldn't tell any difference on the dipstick. The last 2,500 has included a roughly 900 mile road trip at 75 mph plus.
  2. JEAN
    JEAN New Member
    beach
    2 000 miles and dipstick is full.
    1st change at 5 000 miles.
    68 % oil life
  3. bravo3eco
    Are you saying your truck was low on oil?
    are you still here mo mo? GTFO
  5. Aandrews109
    Aandrews109 Member
    Just changed oil at 10,000 miles. May have used a pint at most. Was till pretty much in the same place on the dipstick as when it was changed at 5,000 miles.
  6. quikag
    quikag New Member
    Another data point, got low oil pressure warning on my 2019 at 6200 miles. Was down a few quarts of oil. No bueno.
    Dealer did a free synthetic oil swap and now almost 4K miles into this oil change and it’s down less than half a quart.
    So, oil consumption has basically stopped. Yay!
  7. Old-Dog
    Old-Dog Member
    I have a 2019 Raptor and in less than 3000 miles it ran low on oil. According with TSB 19-2232 the dealer changed the oil and they told me to keep an eye on consumption. Not even 1000 miles later it wasted another qt of oil so the dealer replaced the valve covers and some hoses all according with the TSB... After this, 1000 miles later my Raptor is again 1qt down so replacing the valve covers did nothing but waste my time - the oil consumption is the same as before. My Raptor is close to 5000 miles now and is using 1qt per 1000 miles more or less. According with the Ford TSB the normal oil consumption would be 1qt in no less than 3000 miles. I called the dealer again and they were trying to tell me that 1qt/1000 miles is normal for a Raptor - this makes no sense! Planning to drop the car to the dealer again...
  8. WH7
    WH7 Member
    Update on My 2018. After 3rd oil change at @7500 miles. It does not appear to have used any more oil.
    Currently @10,000.
  9. Vikes91
    Normal consumption my ass. 40000 miles on my 17 and I change my oil every 5000 miles. Never ran low on oil.
  10. Michael lombardi
    Michael lombardi Member
    hello all
    I have a 2019 supercab.. less than 1000 miles and I was low 1/2 quart.. I dont drive the truck much. sits in the garage most of the time... I use it to go to my hunting cabin upstate. but it's strange that it burned 1/2 quart at like 800 miles.. and I dont reall abuse the truck either..
  11. bravo3eco
    Get it to the dealer and start the process. No amount of oil usage is acceptable. Do not let them tell you that. You most likely need the new design valve covers. This has stopped oil usage on some, but others had deeper issues/damage causing more oil to be consumed.
  12. steve semenzato
    steve semenzato New Member
    5200 miles 1 quart used. How often are you guys changing oil? Seems very often!!! Why?
  13. Vikes91
    No matter what car I drive I change the oil 5000 miles maximum.
