Top 15 Tonneau Covers - which do you have?
Discussion in 'Exterior' started by Toadster, Apr 25, 2017.
Which tonneau do you have?
  1. BakFlip G2
  2. Angry Elephant Hard Cover
  3. TruXedo Titanium Hard Rolling
  4. Retrax Pro MX
  5. BakFlip VP
  6. BAK Revolver X2
  7. Roll-N-Lock LG111M
  8. Smittybilt Smart Cover
  9. BakFlip F1
  10. Rugged Liner
  11. Tonno Pro
  12. MaxMate Trifold Tonneau
  13. TruXedo 297701 TruXport
  14. Bestop 19111-01
  15. Lund Genesis
  16. sumthin else! Let us know!
Results are only viewable after voting.
  1. Toadster
    Toadster Full Access Member
    Folsom, CA
    15 Best Tonneau Cover for F150 | HonestInsider.com
    #1 - BakFlip G2
    Features a new “living hinge” set of water sealants
    This cover is the second generation of BakFlip tonneaus. It provides a wide range of benefits, including a tough set of UV protective laminate panels intended to take a lot of heat. The panels are relatively simple to install, yet fold out easily. In addition, this cover features a new “living hinge” set of water sealants.
    BEST DEAL - AMAZON.COM
    #2 - Angry Elephant Hard Cover
    Premium tri-fold cover features with no premium in cost
    This hard tri-fold cover features fiberglass reinforced polymer surfaced panels. It removes in less than 3 minutes. And is ding, dent, and UV resistant.
    #3 - TruXedo Titanium Hard Rolling
    Slat caps keep the cover from overheating
    This cover is built with integrated slat caps intended to keep the cover from overheating, in addition to a UV resistant vinyl coating with a leather grain. With a secure locking system for the tailgate, this cover comes with a 3 year warranty.
    #4 - Retrax Pro MX
    Features sealed ball bearing roller design
    Built with industrial strength aluminium, this tonneau is focused on a low profile design that is capable of being opened and closed with one hand. With a sealed ball bearing roller design, it does not need pull straps.
    #5 - BakFlip VP
    Handles a wide range of difficult weather climates
    Intended to be installed on a wide range of truck models, this cover is built with aircraft grade aluminium and covered in a weather resistant vinyl coating. It's constructed to be resistant to scratches and dings, and is intended to handle a wide range of difficult weather climates. Especially in rain, snow and intense sun.
    BEST DEAL - TONNEAUCOVERED.COM
    #6 - BAK Revolver X2
    Designed for speed
    This tonneau is built with a specialized latching spring system intended to keep the tonneau securely on the truck. With its quality materials, it does not sag or hinder itself when the truck is driven at high speeds or over rough terrain. Additionally, it can improve a truck's mileage when used.
    #7 - Roll-N-Lock LG111M
    Durable value for the money
    This tonneau system is intended to be a durable value for the money. With a vinyl sheet that is constructed over aluminium slats, this cover is a manual open system. It comes with a handful of preset positions intended to make opening it even easier.
    #8 - Smittybilt Smart Cover
    Features unique fulcrum hinges
    This advanced tonneau is notable for its fulcrum system of hinges. These make opening and closing the cover a breeze. With a speed lock system intended to make installation and removal easy. It also comes with a set of nylon reinforced plastic buckles.
    #9 - BakFlip F1
    Heavy duty latches
    Featuring heavy duty latches encased in carefully molded plastics, this tonneau is intended to take a beating. Additionally, the flush hinge minimizes the ice and water build up on the cover of the truck and is designed with high speed usage in mind.
    #10 - Rugged Liner E3-F5509
    Made for 2009 to 2014 F150 truck beds
    Intended to fit in 2009 to 2014 F150 truck beds, this tonneau features an advanced quick clamp system to open and close in less than three minutes. It boasts an easy to assemble set up that requires no tools. It features a tailgate lock intended to improve the truck's fuel efficiency and security.
    #11 - Tonno Pro 42-305
    Tough frame bolstered by 6063 aluminium
    Constructed of 24.5 grade vinyl polyester, the fabric of this tonneau is intended to take a lot of abuse. The frame is tough. It's bolstered by a 6063 aluminium frame. Finally, the tonneau features a powerful rubber seal to keep moisture out.
    #12 - MaxMate Trifold Tonneau
    Built to deal with extremely wet conditions
    This moderately priced tonneau has a set of patented clamps intended to make its installation easy and painless. Coated in a vinyl material with aluminium powder, this was built to deal with extremely wet conditions and comes with a 10 year warranty.
    #13 - TruXedo 297701 TruXport
    Adds aerodynamic contours to your truck
    This tonneau is intended to look good and be functional at the same time. Featuring a design that adds aerodynamic contours to your truck for up to a 10 percent boost in gas mileage. It clamps on easily, requiring no drilling and has a dual latch system for quick release.
    #14 - Bestop 19111-01
    Features an adjustable tensioning system
    This is a rolling model of tonneau, intended to be rolled out quickly and easily. With weather resistant fabric and aluminium rails, this tonneau is sure to last. Additionally, it features an adjustable tensioning system to keep the fabric flat.
    #15 - Lund 95072 Genesis
    Built specifically for 5 feet 5 inch truck beds
    This tonneau cover is built specifically for 5 feet 5 inch truck beds, a common size of F150. It features a trifold opening, intended to allow users to access their truck bed's contents quickly. This cover is designed to last quite awhile with it's tear resistant fabric.
    do you agree? which one do you have? or "other" ?
  2. Toadster
    Folsom, CA
    btw - I'm having the Retrax Pro MX installed today!
  3. gunnersguru
    bootheel if MO
    what about the BAK-flip mx4 ? 3yr warranty . G2=2yr
    Toadster and Vikes91 like this.
    What's the price difference?
  5. gunnersguru
    bootheel if MO
    I got a price quote from a BAK authorized retailer G2=829. with 2yr AND mx4=899. with 3yr installed prices
    Think I paid like 780 for my G2 delivered. Installed myself. Had one of these on my gen 1 since 2010
  7. Vikes91
    I paid 770 for the MX4 delivered. Then paid 40 to get it installed because I like having someone to blame for defects. Which there are none.
    Rodney likes this.
  8. CSJr
    CSJr Member Military
    Marietta, GA
    Backflip VP for 650. Wanted a strong, yet lightweight tonneu so I wouldn't add too much to the payload.
  9. Giorgiob
    Giorgiob Full Access Member
    I love the extant full tilt
    Toadster likes this.
  10. Heme61
    Heme61 Member
    I am going with Diamondback HD in black. I had the polished aluminum Hd on 3 trucks great cover. a bit pricey but it has to be the toughest cover on the market....I would still have it on this Raptor if they didn't change the bed rail dimensions.
    SeaDawg likes this.
  11. Shark
    Shark Active Member
    This time around I bought the Bakflip MX4. I really like the versatility of this one and the fact that I can close the tailgate with the cover down without fear of damaging it.
    [​IMG][/url]
  12. Toadster
    Folsom, CA
    pics of my Retrax Pro MX - and full Line-X treatment in the bed and rear fenderwells :)
    blackhole likes this.
  13. Toadster
    Folsom, CA
    pics of the bed, tonneau covered and uncovered
  14. Toadster
    Folsom, CA
    and the bullring cutout fits perfect ;)
  15. blackhole
    blackhole Full Access Member
    DFW TX
    so much for the top 15 when most of us have something other than the "TOP 15" :) :banana-mario:
    Plasterman, INTEL DRIVEN and Toadster like this.
