KO2 Tire
Discussion in 'Raptor Maintenance' started by moneymaker18, Apr 16, 2017.
Car Parts
  1. moneymaker18
    moneymaker18 New Member
    So I got my Gen2 Raptor about a month ago and overall it's been great. However, since day 1 the truck feels bouncy in the rear. It is noticable at all speeds but very prominent around the 35mph range. I thought it was a break-in issue but I put 1000 miles on it and the bounce is still there. Feels like the tire has a soft spot in the rear. I took it in to Ford and they inspected all the tires and checked the balance ( all tires were good). The problem still exists. I thought the tires would be smoother or is this the way it is? Anyone experience an issue like this?
  2. TruthRoderick
    TruthRoderick Member
    Have you ever driven a truck before? Not being a dick. The first time I bought a truck after driving cars my whole life I thought the same thing. However, I haven't heard of any bed bounce issues with the Gen 2. Maybe somebody else has some better insight.
    Vikes91 likes this.
  3. shelteredraptor
    knock the pressure back to approx 38 psi and see if that helps. Jack it back up after you get used to it. It's a truck, it might ride like a caddy, but it's still a truck...
    blackhole likes this.
  4. Rapere1
    Um, ya..... Ever own a truck before? There's not much weight back there so it's not planted like other vehicles. Now add to the fact your driving a Raptor!!!! It has 14" of travel back there, it's not supposed to ride firm!!!!!!
  5. dirtrider
    dirtrider Full Access Member
    Oxford, Michigan
    Throw 2 50# bags of salt in the back and see what that does.
  6. VT Raptor
    OK GUYS - this is a good one.. Just came back from Ford Dealer 5000 miles on the clock. Got my oil changed (free of charge from my dealer - synthetic blend recommended from Ford) anywho... asked if they would rotate the tires please.. "well Mr. customer we recommend you wait till 10,000 to do that..." "our mechanics feel that the tires are just starting to break in at 5,000 and dont need to be initially rotated until 10k then every 5k after that.." blah blah..... any thoughts Gents?
  7. Gdog
    I call bullshit. I rotate my tires every 5k. Period. I got 65k out of my last set of duratracks
    VT Raptor likes this.
  8. blackhole
    blackhole Full Access Member
    DFW TX
    ya from dealer they had the KO2s cold pressure at 44lb so after heat up they went to like 48 and at high speed i was bouncy balls. Lowered these to 38 cold and now its spring time they warm up to 41-42 which is a big difference at high speed. this is with no load or equipment in rear btw. as texas summer we get up over 100 easy and humid
  9. VT Raptor
    Yeah - So i was poking around the BFG website and one of the reps popped into the online chat box so i asked him. They recommend 6 to 8k depending on what kinda of driving / conditions / towing you are doing.. I called the rep back that i dealt with at the dealer and told him. He put me hold for a sec then came back and said he noted it in the file and I should stop by anytime b/t 6 and 8k miles and they would be happy to rotate my tires at no charge..
  10. redtail17
    redtail17 Full Access Member
    Southwest PA
    Just my 2 cents... I've driven 7 different Ford trucks and they're all light in the back. In winter, I used to throw bags of salt or sand into the beds to add some weight and also have help if traction was needed. On my last truck, I bought a Shur Trax water bladder. You fill with water to add weight, then just drain in Spring. It never did freeze because the truck was kept inside, although it is designed to freeze. It was cleaner to work with than bags of salt/sand and easy to store. If anyone considers this product, I'd say go with the midsize model for the Raptor and be sure to secure in the bed. It will slide on hard braking and it will affect your stopping distance.
    As far as the Raptor, mine bounces especially when hitting pot holes while rounding corners. It feels like the bed is taking off on its on. I'm running 38 in my tires.
    A little off the subject, Weather Tech now has mud flaps for the Raptor. I'm still waiting to see Husky's - possibly mid June.
  11. djt2299
    djt2299 New Member
    You might want to try heavier leaf springs if the bounce bothers you. There are many available in the aftermarket arena.
  12. JaRod
    JaRod Member
    Delray Beach FL
    leaf springs are bouncy its just the way they are designed
  13. Aandrews109
    Aandrews109 Active Member
    Drove a '13 SCrew 4x4 until I recently purchased my '19 Raptor.
    Had KO'2 on the '13 with about 30,000 miles and they were wearing perfectly. Ran 45 psi front and 32 psi rear cold. Rotated every 5000 to 6000 miles. Currently running the same pressure in my Raptor. Ride is really good and no bounce other than normal truck handling. The '13 was definitely bouncy in the rear if I ran over about 35 psi and wasn't hauling a load. What I normally do is air my tires up a little higher than I know I'll need, put a couple of chalk lines across the tread and drive a straight line. I then air them down slowly until all but about 1/2 to 3/4" of chalk remains on the outside of the tires. Have done this for years on all types of vehicles and have always gotten at least the tire's rated mileage with no issues.
  14. Adam
    45 seems high in the front but if it works for you, more power.
