Cam Phaser failure info
Discussion in 'Raptor Maintenance' started by bravo3eco, Apr 15, 2020.
Car Parts
  1. bravo3eco
    bravo3eco Full Access Member
  2. Frank
    Frank Member
    Okanagan Valley, British Columbia
    Does anyone know what percentage of engines have a phaser failure?
    Has anyone had more than one failure on same engine?
    Anyone know the cost to replace them, if truck off warranty?
    Am trying to understand how common the problem is in relation to number of Raptors on the road.
    (ps my 2017 phasers just failed at 35,000 miles)
  3. Hector Cueva
    Hector Cueva New Member
    48k miles and going in to the second set
  4. bravo3eco
    This has a very high failure rate among all 3.5 ecoboost vehicles. Sadly, it has been an issue on these since the original 2010. Ford has released all kinds of changes and updates to fix, but nothing has worked. With this said, repeat failures are common.
    Parts and labor for this is $4k each time it happens.
    This is reason alone to not own this truck while it has the 3.5 ecoboost in it. This is why everyone wants to go back to an easier, more reliable v8. The 6.2 NEVER had this poor of a track record for reliability.
  5. Frank
    Frank Member
    Me again. As I am waiting for parts, dealer has let me continue driving the truck.
    It had an oil change, and now the phaser rattle has stopped.
    Not sure if the noise can be intermittent or not?
    ps Previous oil change was done by Ford dealer so I not sure if issue could have been type of oil as i used a different dealer,
  6. bravo3eco
    You still have the problem. Oil type and filter type don't make a difference.... It is a part design issue in the system. New cam phasers are CD parts, and should probably get the new cylinder heads that have the updated cam phaser solenoid housings.
  7. jimmyv13
    jimmyv13 Member
    I wonder if the cylinder heads are included in the "new" version of the cam phaser fix. If so, I'd guess that repair bill just doubled, at least.
  8. bravo3eco
    I don't know. Scary part is that trucks with the newest design cam phasers (CD) are still failing. It is an inherent design issue with this particular engine. They have tried since 2010 to fix!
  9. FLG2Raptor
    FLG2Raptor Member
    Orlando, FL
    Cam Phaser (non)issue explained ...
  10. Vikes91
    Oh man, those cam phaser issues are devastatin . I better dump my Raptor now.
    bravo3eco likes this.
  11. SnowyStang
    SnowyStang New Member
    Tulsa, OK
    And here I am about to pull the trigger on a 2018 with < 30k. Is this common enough you guys would recommend holding off util there’s a solid solution?
  12. Vikes91
    Dude, it's a nonissue. Even the tech in the video said that.
    Raptor62430 and FLG2Raptor like this.
  13. SnowyStang
    Tulsa, OK
    Yep. I’ve dug in more and agree. I couldn’t take one video as a decision-making justification.
    Thanks for the response!
    Raptor62430 likes this.
  14. Aandrews109
    Aandrews109 Active Member
    Four 3.5 Ecoboosts in my family, all SCrews, two 2012's with around 100,000 on the clock, one 2013 with 130,000, and one '19 Raptor with 15,000. No issues on any of these engines. We all change our oil at 5,000 miles, use Motorcraft Filters and full synthetic oil.
  15. FLG2Raptor
    FLG2Raptor Member
    Orlando, FL
    Oil is the life blood of the Raptor and the key to avoiding failures.
    The engine oil lubricates the turbos. The engine oil (pressure) adjusts the Cam Phaser. Ford is a for profit company and to save costs and increase profit, they don't use the best oil filter or the best oil in the Raptor straight from the factory.
    I've had ZERO issues with my 2019 built in April, but as a pilot, I understand the importance of oil, specifically Synthetic oil in keeping a high performance engine alive.
    At 500 miles I changed the factory oil and oil filter. I use Mobil 1 Annual Protection Ultimate Full Synthetic, designed for vehicles with turbo chargers. I also change my oil at least every 5000 miles and no more. I use Mobil 1 Extended Performance Oil filters.
    I've seen several YouTube videos of oil filters cut open and the Motorcraft filters have very poor quality control especially in the even spacing of the filter media which affects filtering efficiency and effectiveness.
    Mobil 1 Annual Protection oils are recommended for all types of modern vehicles, including high-performance, turbocharged, supercharged, multi-valve and fuel-injected engines that are found in passenger cars, SUVs, light vans and trucks.
    Mobil 1 Annual Protection 5W-30 meets or exceeds the requirements of:
    · ILSAC GF-5
    · API SN Plus Resource Conserving, SN Plus, SN-RC, SN, SM, SL, SJ
    · ACEA A5/B5
    · Ford WSS-M2C946-A, WSS-M2C946-B1 (2019 Raptor Spec)
    What makes Synthetic oil so special? Why does it even exist?
    Synthetic oil was developed before the Second World War and saw widespread use with the invention of the jet engine. The jet engines high engine temperatures and RPM's opened the way for the first wide scale use of synthetic oils. Meanwhile, development of automotive oils continued, and in 1975, the first commercially available synthetic motor oil was launched.
    Since then, and in response to the need for better performing oils, the use of synthetic oils has increased and many auto manufacturers now require the use of synthetic oil in engines.
    The benefits of synthetic oil arise, in part, because it has uniformly consistent properties, unlike crude oil, which is a mixture of hydrocarbons of varying molecular structure and size. Additionally, synthetic oil contains fewer impurities that affect the durability of conventional motor oil. Consequently, synthetic oil lasts longer and provides a significantly greater level of engine protection.
    What is Synthetic Oil?
    As the name implies, synthetic oil is made with products that are chemically manufactured. These products, primarily polyalphaolefins (PAO) and esters, possess many of the same qualities as crude oil but without its disadvantages. The chemical processes permit tight control of the molecular structure of PAOs and esters, ensuring the final oils have uniform and stable properties.
    However, some synthetic oils are made from highly refined crude oil. A process known as severe hydrocracking breaks the long chain hydrocarbons into shorter, more uniform molecules and at the same time reduces the level of impurities in the oil. The oil produced, known as API Group III oil, has almost identical properties to synthetic PAO oil and in the U.S. is regarded as synthetic.
    Why You Should Use Synthetic Oil
    Modern synthetic oils are compatible with all engines, provide better engine protection, and improve performance due to their lower friction characteristics. Selection of the right synthetic oil is easy if simple guidelines are followed:
    • Choose a viscosity rating as specified in the vehicle handbook.
    • Verify the API or ACEA oil specification.
    • Choose an oil with the same or higher API classification.
    • Check oil complies with any mandatory auto manufacturer oil specification requirements (these are usually shown on the oil container).
    Provided the oil complies with the above requirements, it will be compatible. Bear in mind the use of synthetic oil is mandatory in many modern vehicles, especially turbo-charged models, and the use of non-synthetic oil could cause engine damage.
    Synthetic motor oil provides the following benefits:
    • Longer engine life
    • Lower emissions
    • Excellent winter performance
    • Enhanced engine wear protection
    • Minimal deterioration between oil changes
    • Cleaner engines
    I have had ZERO issues with my 2019 Raptor and I haven't had to add a quart of oil because I'm not loosing it being burned up in the turbos. And believe me, I DRIVE my raptor.
