2019 Raptor..Interested in finding an approved ground at both the interior fuse panel and under the tray over the sync3 display. My fat ass does not fit between the seat and dash well enough to see the interior fuse panel very well. I do not see a specific grounding location (bolt) to use for a hard wire inside. The hot is easy... Same under the tray above the sync3 display. I could/can find any number of bolts/screws that will handle a ground for a couple of amps or less DC but would prefer to go to a known bonding location. Thanks.
I used a ground point near the fuse panel by passenger foot well for my Dash Cam's. Think you need to pull the trim piece off to get at it. Also makes getting to the fuse box a lot easier.
Solved..Yes, there is a bolt up high on the forward right side of the angled portion of the firewall. Where the floor turns up into the firewall. Backed it out. Slipped a ring connector on it with a piece of #18ga green wire. Run up near/into the fuse panel area. Connected both the Camera and radar detector grounds. No problems..Ground is good.
