Disturbing intermittent grinding noise
Discussion in 'Raptor Maintenance' started by Wes Skaperdas, Dec 31, 2018.
Car Parts
  1. Wes Skaperdas
    Wes Skaperdas Member
    Powhatan, VA
    I'm a new owner of a used 2018. 12,500 miles on it. Since buying it a month ago it makes an unsettling noise after running for 20 minutes or more. Sounds like when you were a kid and your bike chain got too loose: The sprocket would spin without completely engaging the chain links, making a grinding noise, and then . . . clunk . . . it would engage again. That's as close as I can come to describing it. Sometimes it's just for a few seconds; sometimes it goes on for 10 or 15 seconds. It happens in 7th gear or above and typically above 50 mph. Sometimes it will do it many times in a 30 minute period, and sometimes not at all. Sometimes it stops immediately when I press the accelerator, other times it doesn't.
    Perplexing.
    I have a service appointment later this week but am concerned the service techs won't drive it long enough to experience the problem. Would like to point them in a direction if anyone else has had this happen to them.
    Than in advance.
  2. Adam
    Any video you can post, does it do it on a cold start ? Only other thing for the grinding noise is the IWE. Cheap part but goes out often.
  3. Wes Skaperdas
    Powhatan, VA
    Thanks for replying.
    No . . . only after running for awhile. Sometimes 30 minutes into a drive, sometimes longer. Totally unpredictable.
    I don't have any video but another owner posted a short video that had the same noise: His problem was a cracked front hub.
    My truck is in the shop now, and I shared the video. The service adviser also said there is a problem with a 4WD-related component so they're looking at that, as well.
    I'll post whatever solution they come up with.
  4. Wes Skaperdas
    Powhatan, VA
    Epilog . . .
    Problem was a bad 4X4 Vacuum Check Valve. There's a TSB on it . . . . 182273A.7
  5. Adam
    Easy fix, hoepfully the last
  6. Wes Skaperdas
    Powhatan, VA
    Amen!
  7. CAlex2441
    CAlex2441 New Member
    Literally had this exact problem. Exact. Same year and mileage. I was able to replicate the noise by getting the truck warm, driving for a little, then shutting it off- and turning back on immediately. The grinding noise in full bloom and I have a video I can text you so you can see if it’s the same. I went to Gator Ford in Tampa and they heard it, diagnosed it, and swapped the muffler/exhaust. Problem solved.
  8. Wes Skaperdas
    Powhatan, VA
    Interesting. Another guy posted a video that sounded identical and his problem was a cracked front hub.
    Mine turned out to be a faulty vacuum check valve. Service Tech immediately suspected that when I explained the problem, and there was even a Technical Bulletin on it. It fixed the problem.
  9. Adam
    Glad to hear man, Im up for a fix on Tuesday at dealer
    Wes Skaperdas likes this.
  10. Wes Skaperdas
    Powhatan, VA
    Good luck!
  11. Adam
    Thanks, done and it feels so nice not to have metal grinding at the pedal.
  12. John Cater
    John Cater Member
    I had a noise that could vaguely be described as "grinding" and they said it was a check valve problem. They replaced it but it didn't fix the problem. Would you mind posting that video you said you have so I can compare the sounds?
