CAM shaft
Discussion in 'Raptor Maintenance' started by Rptrgrl, Dec 11, 2018.
Car Parts
  1. Rptrgrl
    Rptrgrl Member
    Has anyone had any Cam shaft issues with their 2017s?
  2. Andrew
    Andrew Member
    Las Vegas
    I haven’t heard or seen anything about cam issues. What do you have going on?
  3. Adam
    Some have failed cams and timing chains, not super uncommon. Some have started at like 3k miles other not until way later. Hard to judge the differences. 30k on my 17 and I am knocking on wood everyday
    Rptrgrl likes this.
  4. Rptrgrl
    Rptrgrl Member
    Heard a knocking. Took it in to the dealership and they said it is a cam shaft defect. Ford is replacing the motor..
  5. Vikes91
    Shut your face. I have 28k with no problems. I will hunt you guys down if I start having problems. :893karatesmiley-thu
    Kevin Baldwin, Adam and Rptrgrl like this.
  6. Rptrgrl
    Rptrgrl Member
    Well new cam shaft timing chain... No new motor
  7. shelteredraptor
    I second this, these gloom 'n' doom bastards can shut the hell up any time now.... " not super uncommon" wtf does that mean Adam?? :Rant:
    Rptrgrl-Good luck getting it fixed, hopefully they do it quick for you
    Kevin Baldwin and Gdog like this.
  8. Adam
    I have heard some cams issues, I have nothing either and my truck is perfect. I think its very small percentage but of the knocking and issues with noise, most are cam or chain issues. Sorry for dumping on the doom ha
    Rptrgrl likes this.
  9. Adam
    Damn, sorry girl
  10. bravo3eco
    bravo3eco Full Access Member
    I think you are referring to the cam phasers. The actual cam is fine. These ecoboost engines have very poor oiling to the cam phasers and the rattling you hear on startup is the phasers chewing themselves up. Once that happens, they stretch the chain.
  11. Comran
    Comran Member
    Los Angeles
    I just encountered a camshaft issue with my 2018 with 8k miles. I just contacted the factory and the dealer. I am an attorney and I will take legal action of Ford does not properly handle this issue. Pending the outcome of my issue, I will update you and try to help if I can.
  12. Adam
    Sorr
    Sorry dude, good luck and keep us updated
  13. bravo3eco
    FYI - There is an aftermarket company that has taken on this cam phaser failure issue. They have detailed why these WILL fail on all 3.5 ecoboost engines and are working on a proper design fix. They are in validation stage with their parts currently.
    The only issue is the owner is on the hook for all of the cost to fix this. Current teardown and rebuild is $6k plus.... Lots of time. With these new parts, not sure how much they will cost.
  14. Vikes91
    Blah blah blah blah
  15. Gdog
    LOL. Your buddy always chimes in with positive info.. He's such a frigging troll
