WHEELS....
Discussion in 'Exterior' started by wparish81, Feb 5, 2017.
  1. Boosh
    Boosh Member
    These are 18x9 SOTA Novakanes that I sent to OMF to put the simulated bead ring on them. They are a zero offset so right now I have some rubbing with the 1.5" rpg collars and 37x12.50's. I can turn lock to lock on flat ground but flexing is not doable yet... It's different, which I love.
    The bottom picture was before I reinstalled the fender liner and flare.
    RibRoy likes this.
  2. Lonnie
    Lonnie Member
    Husky wheel liners are NOW available.... part # 79141. They will start shipping out next week.
    You will have to call husky, they're not on website yet.
  3. htsai14752
    htsai14752 Active Member
    Post your pictures when you get your wheels on.
  4. htsai14752
    How much do these wheels weigh?
  5. htsai14752
  6. htsai14752
    what's also the least expensive forged wheel out there?
  7. CUSTOMWHEELS4U
    CUSTOMWHEELS4U Supporting Vendor Supporting Vendor
    Reno, NV
    Are we talking 17's? If so Roti is 38lbs, CON 6 is 33lbs.
    Innov8's are priced pretty good but they're more built for strength than weight saving. At about 31lbs per wheel you won't find one stronger.
    $490 in raw machined. Caps are $65 each if wanted. These prices do not include shipping.
  8. juan banuelos
    juan banuelos Member
    Here’s mine on RRW wheels matte bronze 17x8.5 factory offset & tires.
  9. Plasterman
    Plasterman Full Access Member
    Maybe silly question but just making sure. I ended up with 20x35’s. I like the way BF’s stock tires rode so hoped the 20’s would too, which is close. What’s the best psi to follow? Vehicles psi at 38 or tire psi at 65?
  10. CUSTOMWHEELS4U
    Reno, NV
    Run 38psi. The 20" BFG has a much higher load rating and smaller sidewall so it will naturally ride rougher.
  11. Plasterman
    Thanks!
  12. Jeff D
    Agree with 38psi. Will drive like a truck wagon at 65psi without a load..assuming your not hauling a load?
  13. Jeff D
  14. Plasterman
    For daily driving. No load for now. Thanks for the help.
