Supplemental alarm for 2018 Raptor
Discussion in 'Audio/Video/Electronics' started by Bruce CREG, May 14, 2018.
  1. Bruce CREG
    Bruce CREG Member
    Los Angeles, California
    I took delivery of my 2018 Raptor with the keyless security entry system and 802A accessory package plus others, but I don't believe they matter concerning improving the current alarm system.
    I'd like to hear recommendations on exceptional quality alarm accessories or systems and my budget would be a less than a thousand.
  2. rob7765
    rob7765 Member
    This is a cheap add on that adds a little more protection with shock/impact.
    https://accessories.ford.com/electronic-module-10670.html
    I sell this bracket to mount it instead of zip ties like the instructions show.
    https://bajamod.com/detail.php?product_code=BM1016&color=
    Also don’t forget about the Ford Pass app for your phone that alerts you to alarm trigger and also lets you arm, lock, unlock, remote start, gps track, etc
  4. stratia69
    stratia69 Member Military
    Lacey, WA
    Can anyone confirm that that module differs from what is already installed on 2018"s? It already has perimeter security that can be adjusted to High/Low through the console. I thought this was an upgrade for previous model that did not have it. Just trying to conform.
  5. Bruce CREG
    Bruce CREG Member
    Thank you for the referral. In checking that part number and your link, it seems it fits the F150 for years 2011-2014 (aka part # DL3Z-19A361-A). This may be the correct part for 2017 & 2018 Raptors, see https://www.levittownfordparts.com/...curity-system-ford-perimeter-plus-p-6139.html for further details. As too stratia69's question, I'm going to check my 2018 Ford Raptor to see if it has the high/low adjustment. I purchased mine with the 802A package along with other accessories.
  6. Bruce CREG
    Bruce CREG Member
    Just ordered my Ford OEM Ford Security System sensor from Fairway Ford (Nate in parts) who was very helpful. Price to CA was $184.95, includes free shipping and they include installation instructions. Link here - https://www.fairwayfordparts.net/oe...g-explorer-super-duty-continental-js7z19a361a
    If your Raptor already has remote start capabilities, then you should be able to install this without taking it to the dealership or so I've read and been told by Nate in parts.
  7. Bruce CREG
    Bruce CREG Member
    My 2018 Raptor includes but is not limited to the 802A accessory package and has remote start, so the part I ordered from Fairway Ford is super easy to install. Install the wiring Y harness into the back of the module with the Data Link Connector (DLC) which is right under the dash on the drivers side. If you're car has remote start you don't need the extra plug that comes with the sensor. I have no idea how you are supposed to install the VSS Module with the included zip ties, none of the holes lined up. When testing the unit per the instructions, wait 20 or 30 seconds after setting the alarm for the first time before hitting the steering wheel to check sensitivity, but mine worked fine with the VSS unit hanging down for the test. I'm going to get some wide velcro and use that to mount the VSS module, however the instructions say "Ensure the tie-strap is routed through the VSS module loopos at opposite corners." If someone has mounted their VSS unit with zip ties, please post. As soon as I install the VSS module with Velcro I'll post pictures.
