Sub and amp
Discussion in 'Audio/Video/Electronics' started by Cowboynch, Mar 30, 2018.
  1. Cowboynch
    Cowboynch New Member
    Corona CA
    Has anyone found a way to get a full signal for an aftermarket amp and sub with the B&O in an 18?
  2. kanaweli
    kanaweli Member
    uh guys have been using forscan since the 17's came out. May want to check previous threads
  4. Bob k
    Bob k Member
    I’m with you.
    I have a 2018 raptor and it has the worst sound system ever.
    No sterio in the front and no rear volume sound in the rear at all.
    Has anyone been able to solve the problem?
  5. Bob k
    Bob k Member
    I’m with you.
    I have a 2018 Raptor.
    Worst sound system ever.
    No sterio in the front and no volume of sound in the rear.
    The system is inter graded with other programs in the truck. Backup and chimes.
    Has anyone had any luck with Ford dealer as I have not.
    Has anyone been able to improve the system?
  6. Bob k
    Bob k Member
  7. shelteredraptor
    Ok Bob, we get yer point.
    Go hunt down Noah at The Car Stereo Company on FRF1 and PM him. If you want a straight answer, that's where it'll be.
  8. shelteredraptor
    And then you can come back here and tell everyone what he says.
  9. HotLap
    HotLap Member
    Subscribed...
    I too am disappointed with the stock B&O system - better than the Sony system - but still weak. What I have found so far is several vendors list the Kicker VSS 200 watt sub/enclosure/amp as fitting the 2018. I've had my 2018 sub out (Dynamatted outside enclosure) and it is the same mounting points as my 2016 King Ranch sub with the Sony system. <Appears> to be the same Amp mounting set up as well. But I have no idea if the electronics are the same or not. I had the Kicker VSS amp/sub and door speaker upgrades and it made the sound decent. Of course the new "Auto Stop/Start System" may interfere with aftermarket components as well...going to have to get the FORScan set up for sure.
  10. Gdog
    PM shelter on here. He dropped 15k on his sound system
  11. Adam
    1/5 that value of my entire truck warrant and taxes lol
