Spd turbo adaptors
Discussion in 'Engine Performance and Mods' started by Brapptor, Apr 30, 2018.
  1. Brapptor
    Brapptor Full Access Member
    Anyone have any experience with these? A Colorado installer recommendation would be appreciated. Thanks
  2. Swe34nes
    Swe34nes Member
    DFW
    Absolutely have them installed. I installed them after the main instructor at Ford Performance’s Raptor Assault program recommended them. The truck feels like it has more and you can defitnitley hear the difference. Deeper exhaust tones, especially higher in the power band and it sounds good to. You can just tell the exhaust is flowing better.
    On the other forum someone has posted side by side pics of the OE adapter next to the SPD. You can see why one is engineered to perform better than the other.
  3. Nexmeister
    Nexmeister Full Access Member
    What was the install like? Can do yourself? Or need to have a pro do it?
  4. Brapptor
    So my truck has 25k miles on it which I’ve heard will make install difficult because the mild corrosion. These are notoriously very difficult
    To install because per the f150 forums and my buddy who can make anything look easy which made me nervous.
  5. Brapptor
    Got a place in Colorado? I’m assuming if the raptor assault guy said it’s cool that it’s warranty friendly. But that could be a terrible assumption
  6. Rapere1
    I had them installed on my truck and glad i had someone else do it at a shop. Broke one of the studs which happens every so often. Better to have it up on a lift with everything needed to deal with it vs. laying on your back under the truck. However it does come down to $$$$ to have someone do the install. I was having other stuff done so this wan't the only thing going on while they had it (new inter-cooler too).
    To me there was minimal difference but it's really needed if your going to get aggressive with other mods.
  7. Swe34nes
    Swe34nes Member
    DFW
    I had a performance shop install mine (Texas Motorworx, they specialize in Raptors and do amazing work if you’re ever in the DFW area). I too was having other work performed but the Adapters were $500 out the door installed. I too would recommend a professional install as it is a PIA job.
    From a warranty perspective, I don’t see how any dealer could tell you have them installed unless they took off the downpipes or turbos to specially see if you have aftermarket installed. Plus they’d have to prove given failure was the result of the adapters.
    Honestly, warranty never crossed my mind. I’d be more worried about a Cold Air Intake than I would the adapters.
    Rapere1 likes this.
  8. Full-Race
    Full-Race Member
    install is not easy or inexpensive, considering the purpose and stated gains. I can not figure out how most people do this without pulling their hairs out. warranty is unlikely to be effected, only the best techs would know what to look for.
    there are strong differences of opinion on the matter of their actual performance increases (not placebo butt dyno increases). As a turbo engineer, I can not see this component doing much of anything to gain power on an otherwise stock internal and stock turbo engine. although it may be a good idea to do if youre installing bigger turbos.
    Rapere1 likes this.
  9. Toadster
    Toadster Full Access Member
    Folsom, CA
