Rough Idle
Discussion in 'New Member Check-In' started by MCFLYGUY, Feb 3, 2018.
  1. MCFLYGUY
    MCFLYGUY Member
    I have a 2018 Raptor, truck has been at the Dealership as they can’t find the issue for the rough idle. Anyone else having this issue? At the moment the truck sounds like a diesel. Dealership thought it maybe issue with the injectors. 9k the issue happens when the engine is warm and cold....
  2. Adam
    Man that sucks, no issues on rough idling. 9600k, keep us updated.
  3. MCFLYGUY
    MCFLYGUY Member
    Just heard back from the dealership, it only took them a week. Possible reason for the noise is a slack timing chain. Fingers crossed this is the problem I'll keep this thread updated as and when I hear.
  4. shelteredraptor
    shelteredraptor Supporting Member Supporting Member
    That sounds like fishy to me, unless the tensioner let go, in which case the thing would sound like a bucket 'o' bolts. Does it smooth out above idle?
  5. MCFLYGUY
    MCFLYGUY Member
    Yeah noise disappears when you rev engine or when driving.
  6. MCFLYGUY
    MCFLYGUY Member
    Update from Ford Motor Co, they are authorizing the replacement of the VCT's whatever they might be! Timing chain was slack.
  7. BabaYaga
    BabaYaga Active Member
    Illinois
    Good luck w the fix, man. Frustrating.
