Oil pan bs
Discussion in 'Raptor Maintenance' started by Iceee187, Jun 7, 2018.
  1. Iceee187
    Iceee187 Member
    under 6000k miles oil pan is leaking. What’s the fix?
    They replace the pan and seal. Pan because it's plastic and usual breaks. The problem is the seal.
  3. xBryanHoodsx
    xBryanHoodsx Active Member
    They now are doing an aluminum oil pan so go in under warranty and make the dealer replace it with the aluminum one
  4. Iceee187
    Iceee187 Member
    Ok thanks guys. 80k truck and it’s had a couple problems already.
  5. bravo3eco
    bravo3eco Active Member
    Folks are finding the aluminum pan is not a direct replacement. There is something different with the oil pickup. Still can upgrade on your own... Just need more parts to make it work.
  6. Redtime21
    Redtime21 Member
    Took mine in for quick lube at the Dealer, they told me there was a leak and the seal needed to be replaced, but I had to make an appointment with the regular maintenance team, not quick lube. I did, they got me in the next week. Changed the seal. Says I am good to go. I was pissed I paid for a oil change just to have another oil change a week later. I didn't have to pay anything for the repair. They clearly should have a full recall for everyone to get it fixed at this point.
  7. Vikes91
    Hmm, I don't pay for oil changes at my dealer.
