I need a side angle view picture of the backside of the rear view mirror to verify something with me blendmount radar detector mount I purchased. Thanks in advance
What do you need? I used the blendmount with a V1. My truck isn't here, it's at the shop. If need be, I can do it later.
Blendmount emailed me and wanted me to take a side view shot of the backside of the rear view mirror from the front passenger seat. I haven't got my truck yet and I guess they don't trust the part number I gave them.
you'll need the one with the very narrow mounting collar, there is a small - approx 5/16" space to mount it. Is that what you're asking? There was a guy on F150 forum that did that exact write-up. I can get a pic in the morning if that isn't too late.
Speaking of this rear view mirror; how do you adjust it or is manual as I'm done reading the damn manual? And yes I can read!
Yeah the truck should be at the dealer for pick up any day now. Just need to see how the mirror tap installs. Didn't know if there was physical plug in the back of the mirror or if you had to pull trim pieces to run the mirror tap
Yes. I pulled both pieces to make it as easy as possible. The trim is simple, but you should get a set of plastic trim tools. Even Harbor Freight has them (https://www.harborfreight.com/5-piece-auto-trim-and-molding-tool-set-67021.html). It's really hard to see to do the mirror tap but they work well. I think I used the second smallest size that comes with the kit.
Perfect! How long of mirror tap cord did you have to use? The one they sent me just doesn't seem Long Enough
