Musty damp smell
Discussion in 'Interior' started by Plasterman, Dec 20, 2017.
  1. HotLap
    HotLap Member
    Another area you might have the dealer check is the Third Brake light housing in the top rear of the cab. I recall that seal can be improperly installed and cause leakage at the rear of the cab...that might even get the rear of the headliner?
  2. Plasterman
    Plasterman Full Access Member
    Thanks. I’ll give that a look! And Check for moisture in the back headliner
  3. Marasco222
    Marasco222 Member
    I’ve got the smell but it seems like it’s coming from the center console between front seats.
  4. Plasterman
    Is it wet there?
  5. shelteredraptor
    Maybe left a ham sammich in there?
  6. Marasco222
    Marasco222 Member
    Nah stunk since I got it. Put baking soda & deodorizer. Nothing helps.
  7. Jesse yoz
    Jesse yoz New Member
    Do not have a musty smell yet, but my 17’ raptor is in the dealer because i noticed hearing alot of water inside my doors moving around (Happened after alot of rain). Originally the dealer was saying a drain vent was clogged, but they called and said it looks like water is leaking in from somewhere but cant figure out where yet. Well its been a week and havent heard much but will update when i know more.
    Plasterman likes this.
  8. Rapere1
    Stop letting fat girls leave their underwear in the glove box and problem should clear up!
    Jesse yoz and Adam like this.
  9. Jesse yoz
    Got my 17’ back from dealer and they claim water was leaking in through the sunroof seal, had alot of rain this week and did not notice any water, but now the inside smells very musty, back at dealer because of how strong the smell is. 17’ with 7,500 miles,
  10. Plasterman
    Ugh. Yeah mine still has a trace of the smell after every rain. Goes away but always comes back. NFG
    They said i had a rubber plug missing in the firewall and tried to blame me because of my rigid lights. I told the geniuses that the wires are factory run inside. It had been much better than before but but perfect so you may want to check that out.
  11. Jesse yoz
  12. Jesse yoz
    Also have rigid lights installed, but all factory wires used, will check that spot also because my firewall lining was damp
  13. Mustang_Dave302
    Mustang_Dave302 New Member
    Mine has a musty smell when you first get in it then it goes away. More so after rain or sitting a long time. Haven't noticed any wet spots. I think its coming from the vents but its getting worse. It's strange, I am highly allergic to mold, and it smells like mold but its not giving me an allergic reaction. I had to sell 6 month old ford Excape because the AC would fill with mold, so bad I couldn't breath or see. Ford said to run the heater on high before you turn off the car. that didn't work. So I sold it. With that car no one other then me could smell the mold. Now with this Raptor I brought with 2,300 miles on it. I starting to wonder if it was in a flood. Currently I auto start the car whenever I can, and I have a air fresh spray I keep in the door. Thank for the heads up I'm gonna check the sun roof and back light.
  14. JD06
    JD06 Full Access Member
    Florida
    I had a leak at the fire wall through a seam that did not have enough seam sealer. Found the underside of my weather tech floor mats had heavy condensation. The carpet was saturated and smelled very musty. I pulled up the carpet on the pass side and it was soaked.
    The dealer sealed the seam. They had the carpet detailed and steam cleaned. Carpet is dry and no smells. It has been 03 weeks. will update if it changes.
