Daytime Driving Lights
Discussion in 'Lighting' started by 18Leadfoot, Aug 9, 2017.
  1. 18Leadfoot
    18Leadfoot Member
    Missouri
    Can somebody post a picture of what the daytime driving lights look like
    yellow outline. google it
  3. sapper_out
    sapper_out Full Access Member
    I believe it's the low beam headlight only, no amber lights at all....I just tried mine and looking in reflections off other vehicles . Good way to save on all yellow / amber lights
  4. 18Leadfoot
    18Leadfoot Member
    Missouri
    I did under images and couldn't find any
  5. CobraJunkie
    CobraJunkie Supporting Member Supporting Member Military
    Connecticut Shore
  6. 18Leadfoot
    18Leadfoot Member
    Missouri
    Cool Look for sure, thanks for posting
  7. RMAN
    RMAN Member
    That picture is technically not the day time running lights!
    To set the day time running lights you have to go to your settings, Vehicle, Lighting, Daytime lights then choose on or off. If you choose on your daytime running lights will come on when you have your light setting set on Auto.
    The lights that come one are your Low Beam Lights!
    I know it makes no sense right!! I played with it for hours trying to get the Amber outline lines to come on! It only makes sense that they would be the ones that come on as daytime running lights, Like all the other new vehicles on the road now a days.
    To get the Amber outline lights on you have to set your lights to the setting right after off! But be careful! They do not automatically turn off when you turn off your truck! or On when set in the auto setting. I had a couple of times I came back out to my truck and saw that I left the lights on!
    I think the reason Ford doesn't use the Amber lights as the daytime lights is because it might interfere with the blinker? making it a potential hazard?
    I'm pretty sure the new 2018 model will have the feature were the amber (or white now?) lights will turn off on the side that you are using the blinker when active! The Raptors are known for having cool lighting, you would think their daytime running lights would also be coolest around?
  8. 18Leadfoot
    18Leadfoot Member
    Missouri
    Agreed, you would think they would have something really cool. Thanks for clarifying
  9. CobraJunkie
    Connecticut Shore
    I used ForSCAN to have the lights pictured on all of the time the truck is running and in gear.
  10. Zaid Dahabi
    Daytime running lights come on when Light Knob is in auto and the vehicle is in anything but Park! The lights here are the low beam lights without non of the LED or Amber lights in the front!
    I used forscan to keep the Front Amber and all around LEDS ON as Daytime running lights! No more low beam DRL!
  11. wparish81
    Ive got to get into this forscan business.. that double honk when you exit the truck annoys the F&@K outta me !! :mad:
