CHIPWERKE PERFORMANCE CHIP TUNING PIGGYBACK SYSTEM 2017+ 3.5L H.O. FORD RAPTOR Free Shipping within the continental US! Unleash the hidden potential in your 2017+ Ford Raptor 3.5L EcoBoost H.O. motor! - Up to ~87 more horsepower - Up to ~97 more ft. lb. torque - Up to ~12% increase in fuel economy Order Link ---->>>> CROWN OFFROAD Discover the true power of your vehicle; get better fuel economy and driving pleasure of vehicle, safely, easily and in minutes! ChipWerke Pro Chip Tuning piggyback system for has a plug-in upgrade for you! Unlike “ordinary” tuning systems, this unit has been specifically programmed for your vehicle. This sophisticated, microprocessor controlled unit simply plugs in using connectors which are identical to those originally installed by the manufacturer – there are no wires to cut. This means installation is a simple task that will take a few minutes of your time. Every ChipWerke Pro Chip Tuning piggyback system for system now comes with a 14-day money back guarantee from the receipt date and 2-year product warranty, so you can buy with absolute confidence. Free your vehicle from its manufacturer’s limits: Order your fully digital tuning kit online today, then fit in just minutes and feel the difference for yourself. Faster acceleration, safer overtaking, more direct response characteristics: Simply more driving pleasure! The SPC5 32-bit Automotive MCUs Processor Microelectronics is one of the most used micro-controllers for complex control. Individually Adjustable Performance All boxes come pre-set for optimal power and fuel economy so adjustment is not necessary: you can simply plug-in and enjoy! After figures show the power your vehicle will produce on the provided settings. Max figures show the power your vehicle can produce on a higher setting. Not all vehicles will achieve max figures on a higher setting; most standard vehicles will achieve a power between after and max figures, which is up to 35% more HP and up to 25% more Torque Fuel Saving With Economy Tuning Depending on your personal road behavior you can save fuel by installing ChipWerke Pro Chip Tuning piggyback system for . Your vehicle will consume up to 15% less fuel while increasing its performance at the same time. If fuel saving is your main requirement, please inform us when placing the order. We will consider this when programming the basic setting. Sub-D-Plug Automotive Grade Components Data connections shall be fast and safe. We have equipped ChipWerke Pro Chip Tuning piggyback system for with proved Sub-D-plugs, which comply with the common standards for electronic plug connections. Therefore you can be sure that all data flow without noticeable delay and no connections will come loose. Rugged Aluminum Casing A solid aluminum casing protects ChipWerke Pro Chip Tuning piggyback system against the negative outside impacts which may affect its performance. Under normal driving conditions, the insides of a ChipWerke Pro Chip Tuning piggyback system are perfectly protected. Even the starting model is splash-proof. However, it is recommend that before washing engine, remove the ChipWerke Pro Chip Tuning piggyback system as it is possible for moisture penetration. Failure to do so may void warranty. Easy Installation; no experience required OEM harness set for plug and play installation SPC5 32-bit Automotive MCU's Processor Adjustable performance settings Heat-Resistant Aluminum Box Removes All Disadvantages of Electronic Gas Pedals Excellent Customer Service Fitment: 2017 3.5L Ford Raptor 2018 3.5L Ford Raptor Order Link ---->>>> CROWN OFFROAD
