Switch Pros SP-9100 Gen2 Overhead Console Mount
Discussion in 'Interior' started by CrownOffroad, Mar 13, 2018.
  1. CrownOffroad
    Boston, MA
    Swarfworks Switch Pros SP-9100 Gen2 Overhead Console Mount
    Fitment:
    2017-2018 Ford Raptor
    2017-2018 Ford F250/F350
    2015-2018 Ford F150
    Swarfworks has done it again! Another custom mount made specifically for newer Ford trucks. If you've run out of auxiliary switches with all of those lights, horns, air compressors and winches, here is the solution. This custom mount replaces the OEM sunglass holder in the overhead console.
    These made in the USA custom overhead console mounts are produced on a high quality 3D printer from durable plastic. The Switch Pros SP-9100 screws into the the 3D printed mount and the mount snaps right into the OEM overhead console.
    Please note, the red mount detailed in the pictures is only for illustration purposes. All mounts are produced in a black finish designed to match the OEM interior panels.
    *Switch Pro SP-9100 Kit is not included but may be added as an optional accessory
    Order Link ----->>>> FORDRAPTORLIGHTS
  2. Andrew
    Andrew Member
    Las Vegas
    This is awesome! Just bought it, hoping the install isn’t too much of a hassle. Will definitely share some pictures of the finished set up with 10 Baja Designs Squadron pros in my ADD bumper!
    CrownOffroad likes this.
  3. Zaid Dahabi
    Whats the difference between this and the whole kit?
    Does this alone work properly?
  4. Rapere1
    Yes please, do share on the install experience.
    I think this will be my next upgrade.......
  5. CrownOffroad
    Boston, MA
    Sorry for the delay in response! The difference in pricing is the mount as a stand alone item versus the mount and the Switch Pro 9100 kit. Install is relatively simply. You remove the overhead console, pop out the glasses holder and pop this new mount into place. We're working on more detailed instructions, but nothing available as of yet.
