BuiltRight Industries has done it again with another great accessory for your Raptor! If you're looking to mount a cell phone, GPS, dash cam, radar detector or other accessories, look no further than the new dash mount specifically built for the 2015+ F150 / 2017+ Raptor. Features: Mount your cell phone, GPS, dash cam and other accessories with ease! Laser cut and CNC formed for perfect fit Durable black textured powder coat Made in the USA Patent Pending Order Link ---->>> Link to ORDER ----->>>> FORDRAPTORLIGHTS The BuiltRight Industries Dash Mount provides a rigid, durable mounting point for all types of accessories. With room for multiple mounts, users can attach and configure their devices with infinite adjustability. A popular combination with our product testers was cell phone, radar detector and dash cam, from left to right. The Dash Mount was born from the lack of phone mounts that give you the ability to position your device where you want. 'RAM' brand ball and socket mounts are an excellent addition to the Dash Mount and although we don't yet have them in stock, they are readily available on Amazon. The slots used in the design are sized to accommodate AMPS standard attachments. Installation is very straight forward. The laser cut and CNC formed bracket attaches to the tray located above the dash using four machine screws, included in the hardware kit. The four .25" holes used must be drilled by the user in the OEM tray. Should you choose to return to stock, the OEM rubber mat inside the tray conceals the holes. The bracket is manufactured from 12ga mild steel and finished with a durable black texture powdercoat - a very close match to the OEM dash finish. Each kit contains the Dash mount bracket, four machine screws, four washers and four locking nylon nuts. Also included are printed instructions and a BuiltRight sticker! Order Link ---->>> Link to ORDER ----->>>> FORDRAPTORLIGHTS
The BuiltRight shelf is cut on the top to accomodate AMPS style mounts. Typically small bolts would anchor these mounts to the shelf itself. Because the shelf is made out of steel, magnet mounts will also work but are not recommended for offroading. Here's a few images of RAM mounts with the AMPS mounting capability:
