Beadlock wheels
Discussion in 'Exterior' started by JAX84, Nov 11, 2017.
  1. Gdog
    Too each his own. Can't wait to see pics
  2. Gunnar Texas
    Gunnar Texas Member
    Dallas, Texas
    Are you adding 37" tires with that high of a lift?
  3. Nwade
    Nwade Member
    Yes sir
  4. Gunnar Texas
    Gunnar Texas Member
    Dallas, Texas
    I'd love to hear & see how it goes. The company I'm working with says there will be some tire rub on ship turns. I'd be curious to hear what your experience is? What tires did you go with?
  5. Nwade
    Nwade Member
    Still waiting on truck to be delivered. But have the lift and tires bought. I went with 37 12.5 r20 Toyo r/t’s
  6. Gunnar Texas
    Gunnar Texas Member
    Dallas, Texas
    That is the set up I was looking at. I look forward to seeing pictures and hearing about the ride once you get it done.
  7. sphf250
    sphf250 Member
    Maryland
    I bought factory beadlocks from a member on another forum, because I am not one for the polished stock wheels. They seem to sell fairly quickly if they are priced right. Prices are all over the place. Saw $2,800 all the way to $1,200.
  8. Beto
    Beto Active Member
    Yuba City, CA
    I wouldn't mine taking the factory beadlocks off your hand. What do you want for them?
  9. Beau
    Beau Member
    That's not quite true. According to Fabtech "The lift is built around a front and rear 1/4" thick steel crossmember that relocate your Raptor's LCAs, while differential drop brackets bring down the factory front differential. A pair of ductile iron steering knuckles with lifted spindles relocate and correct the geometry of your Raptor's CVs, UCAs, and tie rods. The kit adds 4" of front ride height to your 2017-2018 Raptor with a set of shock extensions that allow you to keep the factory 3.0 Fox Coilovers. For the rear, Fabtech includes a complete rear block kit and shock extensions for the rear Fox shocks. A 1/4" thick skid plate is included for bridging the crossmembers and protecting the front differential."
    Also "Cutting Required: this lift kit requires cutting your Raptor's subframe and other components for installation."
  10. Todd DeJulius
    Todd DeJulius New Member
    I was looking at this lift for me 2019 but then noticed there is cutting so not not sure. Does this void your warranty? You got some pics of your truck now that it’s finished?
  11. Wufpackr
    Wufpackr New Member
    Northern VA
    I replaced my 'standard' rims with bead locks a couple of weeks ago. The dark wheel against the Av Grey looks great!
